brodix intake valves >
Old 10-14-2011 | 03:02 PM
Default brodix intake valves
I purchased a new set of Brodix bb3 cnc heads for my spare long block build and I'm going to swap out the exhaust valves for fererra super alloy valves, I talked to brodix and they said that the standard intake valves that came in the heads will be fine for marine use, does anybody disagree with that? I have no problem spending the money and buying better intake valves but if its not going to make a difference then whats the point
JasonKelowna is offline
Old 10-14-2011 | 04:51 PM
They should be fine.
Scott Foxwell is offline
Old 10-14-2011 | 05:01 PM
Find out what material/series valve is in the head.If the series is a ferrea 5000 or equivalent,then they need to go.If there 6000 series or better,then you'd be fine.
I take it these heads will be on the whipple motors?Then get good valves.
shaun harrington is offline
Old 10-16-2011 | 09:15 AM
Brodix valves will be fine. I have run several sets of the brodix valves on blower engines and never had a single problem.
catman01 is offline
Old 10-17-2011 | 03:13 AM
SFOcean's Avatar
Charter Member #394
Only had 35 hrs on them in a blown deal, but the Brodix valves in my 2x heads were in fine condition; both intake and exhaust were Brodix installed parts. So, I would not be concerned with their intakes. I am re-using their intakes and replacing the exhausts with superalloy just to make myself feel better.
SFOcean is offline
Old 10-17-2011 | 09:50 AM
If you have an open cooling system make sure the guide clearances are right.
Old 10-18-2011 | 06:39 PM
mcollinstn's Avatar
Exhaust Valves are your concern. You shouldn't have problems with the intakes. They pretty much stay closed, happily transferring combustion heat into the valve seats, while the "inferno" is happening.
High rpm nitrous or blower motors that are susceptible to valve float definitely need fireproof valves.
mcollinstn is offline
