13 plate oil cooler or Teague cooler?
I am up grading my oil cooler and can’t decide between a 13 plate oil cooler and Teague oil cooler. Has anybody run both styles which one cools better for a 1000HP on long runs? Trying to keep the oil temp down to 220 degrees or less at WOT.
http://www.cpperformance.com/p-14608...-assembly.aspx
http://teaguecustommarine.com/index....il-cooler.html
Offshoreonly Advertiser
Great question! It really depends on the style of bell housing you are running.
We run our 4" dual pass cooler on all of our Bravo applications up to 1000hp+. We have noticed that they are much for efficient than a std 3" cooler and also makes the plumbing a breeze. We make SS brackets that allows for easy and solid mounting to the stringer or a floor. We see oil temps to consistently run under 160 deg with non thermostatted engine water.
As for the Transmission set-ups, we run the the 13 plate coolers on the bell housings. They work awesome, they hold the same constantly cold temps. With the bell housing coolers, we have a trick set up to run a separate cooler between the coolers.
Honestly, I would recommend you to goeither way and we can help you to plumb both correctly and efficiently. I would recommend to run either -20 or 1 1/4" hoses for your water and -12 or 3/4" for your oil.
Give us a call if you have any questions at all!! -Eric
I have 1-1/4" water and #12 oil lines now.
