merc 525sc head + cam upgrade!!
9.3:1 with the right tune and setup at 6psi and 93 octane will give you a good margin of error. Mine were as high as 9.6:1 last year with 6.2psi but I did end up breaking a crank. But that was a engine builder issue not setup or detonation I'm pretty sure. My engine builder can be a real putz at times.
I am afraid to go more than 8.5:1 at 5-6 psi...... It will give an effective comp ratio of around 13.0:1 it is little higher with 92 fuel.
Are you in high altitude???
No, close to seas level on the chesepeake. I don't think your dynamic compression estimate is right but don't have my chart with me at work. From memory my setup at 6psi and 9.5 was 13.4:1. With my 4.8psi pulleys it was mid 12:1s I have engines tore down now and there is no signs on the piston tops of detonation on the 9.6:1 engine. There is a broken crank though but that is a different story.
Hey Dave, I didnt know you broke a crank. Rough.
I am sure that you will have it back together for next season ready for another shot at the old single engine Kryptonite
Dave's (Blue Thunder) boat hauls some serious ass.
