who tunes 496's
Anybody know who can tune, or in my case, pull a tune file off 496s, and if they had to, re-tune some basic tables...I would like to see where my timing is.
Before someone says tuning doesn't do anything with stock 496s, i might add that these aren't stock. Intakes, TB, heads, cams, pistons, etc...
Mark at Precision Marine.
See link below.
See link below.
Whipple or Raylar
You are going to end up with a similar performance based re-program either way. Basically you can give them any other parameters you want. You can select where your rev limiter is, maybe decrease the knock sensor and maybe a little input on your advance. I had Whipple stage 3 and it recommended 93 octane and I ran just about everything thru it but piss and never had any problems. If you have a rebuilt 496 with a good bottom end upping the stock rev limiter will obviously give you some gains right off the bat. You can go thru each parameter and map every cylinder for perfect A/F but it will take a long time and it aint gonna cost you $750 like a standard re-flash.
