K-Plane Sender Fix >
K-Plane Sender Fix
K-Plane Sender Fix
Old 06-14-2002 | 10:51 AM
Shooter's Avatar
Charter Member #300
Default K-Plane Sender Fix
Here's an odd question for a fix.
I have the 110S Kplane. It has electronic senders - it's basically a thin rod with very fine wire wrapped the entire length. A scraper slides along the rod/wire and indicates to Gaffrig trim gauges the tab position.
One of the rods has the wire broken 3/4's way through, so I need to do the one-one thousand, two-one thousand to adjust. I checked with mercruiserparts.com and they say I cannot buy the sender alone, just the $400 assembly. My question is; do any of you guys know where I can get this sender repaired? Probably re-wrap the wire along the rod. I'd assume an electronics store that has some skills, not a part-swapper.
Any info would be great.
Shooter is offline
Old 05-13-2003 | 06:57 PM
duunoit's Avatar
I have the same k-planes and my gauges aren't working. I think it is the sender. Did you find a place to get it fixed or replaced?
duunoit
duunoit is offline
JasonSmith
Do It Yourself, Boating on a Budget
2
10-10-2008 07:21 PM
Zanie
4
05-10-2005 12:33 AM
Danny_Ocean
4
04-05-2004 10:47 PM
duunoit
2
05-13-2003 06:13 PM
blue64drop
6
11-11-2002 11:46 AM
