best   performance exhaust for  496 engines? >
Old 11-17-2011, 04:55 PM
i remember seeing a few posts on here about people having pretty good results with the Dana exhaust on 496's
pstorti is offline
Old 11-30-2011, 11:58 PM
i was thinking the same thing, what are good improvements to make to the 496 ho?
BIGBREW is offline
Old 12-01-2011, 05:03 AM
Sell it and get Eddie Young to build you a 650
There is the Raylar 103 kit, but the cast internals are not really up for the job. When you start to mod the 496's, the internals has to be upgraded as well for good reliable power.
A.O. Razor is offline
Old 12-01-2011, 06:22 AM
blue thunder's Avatar
Originally Posted by endeavour32
Agree 100% with this statement. CMI will only last so long and then they will leak. The KE's will last much longer than any tude header and you'll never have to worry about leaks!
Nearly 10 years of hard running on my 2 sets of KEs and they are still basically like new. Best marine pipe going unless you are in heavy salt and don't flush.
blue thunder is offline
Old 12-01-2011, 07:14 AM
i've seen some dyno results,and the KE really perform good...the others give you power at high rpm mostly
pqjack is offline
Old 12-01-2011, 01:39 PM
Biggus's Avatar
Stock Merc 496? If so, save your money. The factory manifolds work very well for the application and are durable. A bud installed the CMI headers and saw zero gain in performance.
Biggus is offline
Old 12-02-2011, 08:11 AM
Knot 4 Me's Avatar
+1.
Knot 4 Me is offline
Old 12-02-2011, 08:28 AM
Best exhaust for a stock 496 HO? Stock aluminum manifolds. The ports are huge and capable of flowing more than the engine can give them.
thirdchildhood is offline
Old 12-03-2011, 11:27 AM
Couldn't agree more. If you feel compelled, pull the manifolds off and do some minor port work on the holes and put it back on.
I think the stock 496 exhaust kit is one of the very best "stock" exhaust systems out there. It flows well compared to most (all) other Merc exhausts, the riser is stainless so it will be around forever nearly & it's a dry joint so you won't see any of the constant leaks and failing gaskets unless you neglect it.
On a stock 496, there is not a kit out there that will increase the speed of your boat solely on its own. Anyone who makes that claim is not being forth right in my opinion..
If you can not turn a bigger prop or turn your existing prop faster you are wasting your money. An exhaust upgrade on its own with the 496 will not allow for either of the two scenarios.
Better off to lab the heck out of the next size up prop and that's as good as it gets and it's usually under a thousand bucks to do so.
Last edited by SDFever; 12-03-2011 at 11:31 AM. Reason: removed "way" cause it's close to a grand
SDFever is offline
