blowers?
Old 11-26-2011 | 09:40 AM
Originally Posted by Coolerman
For all out power, I'm kind of partial to the PSI's Vor-Tech makes some nice stuff to.
If you like roots blowers, the blowershop stuff will run forever.
nice !!!!!!!!!!!!!!!
ROCK ON !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
ITS A SKATER NATION !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 12-04-2011 | 11:15 PM
That question is completely dependent upon your primary platform. If you are running a fuel injected setup (MPI variation) and have deep pockets, I would recommend whipple chargers, followed closely by Vortech. If you are running carberated motors, I recommend an 871 blower with a superchiller at minimum, prefereably though a 1071. The larger the blower, the cooler the intake air is, thus decreasing chances of detonation. I personally prefer old school roots style blowers with carberators because I can actually work on them and self diagnose. However, if you have the correct MPI setup with Whipples or Vortechs, this is a very nice setup as the computer controls fuel flow, air/lean mixture, timing, etc. Hope this helps!
34Mach1 is offline
Old 12-05-2011 | 06:52 PM
weldcrane's Avatar
10/71 and carbs that is what i plan on doing thanks
weldcrane is offline
Old 12-05-2011 | 07:46 PM
10/71 with throttle body EFI is a nice combo too. You get the benefit of precise fuel metering at every rpm and load point, knock protection, timing control, rev limiter's, etc. for no more $ then a good set of blower carbs..
HaxbySpeed is offline
