Inconel Exhaust valves. >
Old 11-25-2011 | 03:13 PM
Registered User
Default Inconel Exhaust valves.
Pulled my engine last week, Blown whipple deal (had 2 exhaust valves going away) We pulled the heads and indeed the valves are beat. I cant find any part numbers or manf. name on them. Is there an easy way to tell if they are inconel, S.S or other?? I don't know the history of the heads, so I dont know what they are. Plus would love a sure fire way to tell the difference.
Thanks, Dave
boatcrzy is offline
Old 11-26-2011 | 09:12 AM
bcfountain's Avatar
Registered User
you can use a magnett to check the valves in question.magnett willnot stick to the inconel valve.i am not sure of part#.my motor guy is doing a set of heads now and using ferra valves.they are about 40 dollars for one.
bcfountain is offline
Old 11-26-2011 | 11:52 AM
The inconel valves are only the inconel material at the head, the stem is stainless steel. You can check them with a magnet but I do not recall which end of the valve should be attacted by the magnet. So if a magnet pulls on one end of the valve and not the other they are inconel.
Inspector is offline
Old 11-26-2011 | 12:30 PM
Magnets don't stick to ss either so....
Pismo10 is offline
Old 11-26-2011 | 01:08 PM
CNC's Avatar
CNC
I have a Ferrea exhaust valve in my hand, magnet sticks to the stem but "not" the valve head.
CNC is offline
Old 11-26-2011 | 02:41 PM
Rookie's Avatar
And I believe they are heavier. You can feel the difference in the head of the valve.
Rookie is offline
Old 11-26-2011 | 06:39 PM
Dave,
Take a magnifying glass and look real close around the top of the valve. The numbers can be very hard to see. If they are Manley, they will not have a part number, only "Manley" and a code. Ferrea's numbers will start with an "F"
HTH,
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 11-28-2011 | 05:14 PM
mcollinstn's Avatar
Magnets stick to lots of stainless steel. Just not the common 300 series ss which is what is used on refrigerators and sheetmetal items. I'm pretty sure valves use a 400 series magnetic stainless. Inconel is ALSO available in magnetic and nonmagnetic. Depending on the constituents used in a particular grade of inconel (a high nickel stainless), it may or may not be magnetic.
But YES, if your stems are magnetic and the valve heads are not, they are very likely "Inconel".
MC
mcollinstn is offline
Old 11-28-2011 | 05:17 PM
MC
+ 1
it's amazing the number of people that still think that all stainless alloys are non-magnetic...
pqjack is offline
Old 11-29-2011 | 12:19 AM
Question
Sorry, sort of a simple question here. What is the engine, what type of heads are we talking about here? It always helps with these type of questions for answers if we have good base info.
Best Regards,
Ray @ Raylar
Raylar is offline
