RH or LH ??? >
RH or LH ???
RH or LH ???
Old 06-15-2002 | 10:51 PM
waden54
Question RH or LH ???
Just need confirmation hoses are hooked up right.
My motor=454 LH(standard rotation).
Using Prop for RH.
Intake hose to RH on seawater pump.
Correct?????
Wade
Old 06-16-2002 | 09:28 AM
kook
Default Re: RH or LH ???
Using Prop for RH.
Wade
huh? You talking about the rotation of the crank as viewed from the back of the boat?
Old 06-16-2002 | 09:59 AM
Audiofn's Avatar
Charter Member #232
I think what he is asking is the hoses that go into the water pump. You can put them on for RH rotation or LH rotation. This is done for the motor it has nothing to do with the drive at all. So if your motor is LH rotation your hose from the raw water pump should go to the LH in side.
Jon
Put your best foot forward!
Audiofn is offline
