Help to identify block yr and 2 or 4 bolt >
Old 12-09-2011 | 08:13 PM
Default Help to identify block yr and 2 or 4 bolt
Casting # is 10114182
I know it is a 454 but I have seen some people say it is a 2 bolt and some say 4 bolt. I am wondering if anyone knew for sure.
Also wondering if there is any way at all to tell if heads are oval or square port by looking at them without taking anything apart? Any distinguishing characteristics?
Baja226sport is offline
Old 12-09-2011 | 09:00 PM
according to my book its a1992-95 ho crate/truck block it also can be a 2 or 4 bolt main.hope this helps
ext2gtx is offline
Old 12-09-2011 | 09:01 PM
1991 up Gen 5 4 bolt main From Mortec
You can pull off a valve cover and get the number off the head.
picklenjim is offline
Old 12-09-2011 | 09:03 PM
1991+ 454, 4 bolt, Generation V if a 330hp and all stock it has all cast crank, pistons and small rods it's a peanut engine. not worth much. other than the block there where 365hp mags' out there too.
Rockfish71 is offline
Old 12-09-2011 | 09:08 PM
0-326711.....................4-bolt, Alum., CanAm, 4.44" bores, steel cylinder liners
340220.....427T......68-85...4-bolt
345014.....454.......70-86...
346236.....454.......75-76...2-bolt
359070.....454.......70-90...
361959.....454.......73-90...2 or 4 bolt
364776.....427T......68-85...4-bolt
364779.....366T......68-90...4-bolt
399204.....509.......70-71...4-bolt, Alum., CanAm, 4.5" bores, steel Cylinder liners
399293.....366T......77-78...4-bolt
473478.....427T......77-90...4-bolt
495102.......................4-bolt, Alum., CanAm, 4.5" bores
3782870....427T......68-76...4-bolt
3824553....366T......66-67...4-bolt
3855961....396.......65-66...2 or 4 bolt
3855961....427.......66......2-bolt
3855962....396.......65-66...4-bolt
3855977....366T......66-73...4-bolt
3869942....427.......66-67...2 or 4 bolt
3902406....396.......67......2 or 4 bolt
3904351....427.......67......2 or 4 bolt
3904354....366T......66-76...4-bolt
3916319....366T......68......4-bolt
3916321....427.......68......2 or 4 bolt
3916323....396.......68......2 or 4 bolt
3925521....427T......68-85...4-bolt
3935439....427.......68-69...2 or 4 bolt
3935440....396.......68-69...2 or 4 bolt
3937724....366T......68-85...4-bolt
3937726....427T......68-84...4-bolt
3946052....427.......69......4-bolt, Alum. ZL-1, Mark IV
3946053....427.......97-up...4-bolt, Alum. ZL-1, 2nd version, Mark IV
3955270....427.......69......2 or 4 bolt
3955272....396.......69......2 or 4 bolt
3955274....366T......68-85...4-bolt
3955276....427T......68-73...4-bolt
3963512....427.......69......2 or 4 bolt
3963512....454.......70-76...2 or 4 bolt
3969852....366T......68-84...4-bolt
3969854....396.......69......2 or 4 bolt
3969854....402.......70-72...2 or 4 bolt
3969858....427T......68-84...4-bolt
3999289....454.......71-79...2 or 4 bolt, some "CE" replacement blocks had four bolt main caps
3999290....396.......68-69...2 or 4 bolt, Truck
3999290....402.......70-72...2 or 4 bolt, Truck
3999290....402.......72......2 or 4 bolt, Passenger
3999293....366T......68-90...4-bolt
3999294....427T......68-84...4-bolt
10051107...454...............4-bolt, Bowtie, MkIV, 9.8" deck, siamesed bores, 4.25" semi-finished bores, can be bored to 4.50"
10069282...366T......90-91...4-bolt, Mark IV, Tall deck
10069284...427T..............4-bolt, Mark IV, Tall deck
10069286...454.......90-91...4-bolt, Mark IV, Short deck
10114182...454.......91-up...4-bolt, Gen.V
10114183...366T......91-up...4-bolt, Gen.V
10114184...427T......91-up...4-bolt, Gen.V
10134366...454T..............4-bolt, Bowtie, Gen.V, Tall deck
10185050...454...............4-bolt, Bowtie, Gen.V, Short deck
10237297...454.......96-up...4-bolt, Vortec 7400", "L-29" Gen.VI
10237299...427T......96-up...4-bolt, Gen.VI, 7.0L, truck
10237300...502.......96-up...4-bolt, Gen.VI, 4.466" bore
12550312...427T......96-up...4-bolt, Gen.VI, 4.250" bore, fuel pump boss, clutch linkage pivot boss
12550313...454.......91-up...4-bolt, Gen.V crate motor, Gen. VI 4.25" bare block, fuel pump boss
12556110...496.......01-up...4-bolt, Gen.VII 8.1L, "Vortec 8100", Truck
12561357...454.......96-up...4-bolt, Gen.VI
12561358...502...............4-bolt, Gen. VI
14015443...454.......87-90...2 or 4-bolt, Mark IV, Truck, Motorhome
14015445...454.......78-90...2 or 4 bolt
14044807...454T..............4-bolt, Bowtie, MkIV, CNC prep, Tall deck, 4.25" bore or 4.495" bores
14096859...502...............4-bolt, Gen.V, HO
24502504...454...............4-bolt, Bowtie, Gen.V, Race prep, 9.8 "short" deck height
24502506...454T..............4-bolt, Bowtie, Gen.V, Race prep, 10.2 "tall" deck height
24502572.....................4-bolt, 4.5" bore Olds DRCE 2, 9.5" deck height
25534402.....................4-bolt, 4.590" bore Olds DRCE 3, 9.25" deck height
charliem is offline
Old 12-09-2011 | 09:10 PM
Those engines have 088 heads, and the block suffix code will show they are over the counter LS-6 (XXA code) engines
charliem is offline
Old 12-10-2011 | 07:26 AM
Where do you find that code?
Old 12-10-2011 | 09:28 AM
on the pad in front of the r/s cylinder head
charliem is offline
Old 12-12-2011 | 06:21 AM
pop the valve cover...if you see PASS is a oval port..Hi-PERF if its rect...top section of head..big letters....no real way on the 4 bolt mains without pulling the pan..
ezstriper is offline
Old 12-12-2011 | 05:15 PM
mcollinstn's Avatar
Is it a STOCK "unmodified" Mercruiser motor? If so, then the 330/310 hp is oval/peanut port heads. The 365 hp is a rectangular port head.
454's are some 4 bolt and some 2 bolt. The casting number will not guarantee which one.
MC
mcollinstn is offline
