-   -   Starting 2001 502MPI on Stand (https://www.offshoreonly.com/forums/general-q/267200-starting-2001-502mpi-stand.html)
matthewr 12-14-2011 07:18 PM
Ive looked at all the wiring diagrams for this motor. I need to start this motor in order to get this sale completed. Does anyone have an easy reference for hooking up only what wires i need to make it run. I dont need gauges or anything like that. Thanks guys.
offthefront 12-15-2011 07:18 PM
Battery Positive to the Solenoid on the starter
Battery Negitive to block
run a #10 wire from the positive of the battery to the red/pur side of the solenoid on the motor ....(this is the hot wire from the ignition..ie run ...you'll have to lift this wire to shut the motor off ....
jump a positive from the battery to the yel/red small terminal on the motor solenoid to start .....
I think this is right .....be careful....m
matthewr 12-15-2011 08:03 PM
I got er. I appreciate the help. On this motor. + from battery to starter, ground to bell housing. On the mercruiser plug on the motor. Hook 5(purple) and 6(red with purple stripe) together, number 7(red/yellow) wire touch it to 5 & 6 and bazinga!
I cant take credit. I studied the diagrams for a bit. Eric from EB marine gave me call and told me to tie 5 and 6 together.
sonicss42 12-16-2011 07:20 AM
Please don't do this on an engine building stand but use something low to the ground.
bcfountain 12-16-2011 08:17 AM
put your motor on a engine dolly and put 4+4s cross ways under the dolly and afix the 4+4 to the dolly.this way the engine will not flip over in the floor when your running thr motor.
matthewr 12-16-2011 12:23 PM
Its on a pallet bolted down.
onesickpantera 12-16-2011 01:16 PM
Now that is an ugly visual!!!
bcfountain 12-17-2011 11:11 AM
no chit,could you imangine that big hunk of cast iron getting away from you.better have steel toe boots on.lollol
ezstriper 12-19-2011 06:25 AM
why ?? other than oil pressure and run period thats all you be able to tell....
matthewr 12-19-2011 10:12 AM
Would you buy an engine you couldn't hear run?
