limor to 502 swap >
limor to 502 swap
limor to 502 swap
Old 12-25-2011 | 08:44 AM
crayolacrazy's Avatar
Default limor to 502 swap
can anyone tell me if theres a problem doing this .A freind of mine is looking at a38 fountain non stagered that had ilmores is the x dimention the same for these motors and bellhouseings wiringharness plug motor mounts ect.
crayolacrazy is offline
Old 12-25-2011 | 09:36 AM
I don't believe they're the same, but if he's gonna change them out, I may be interested in the Ilmors. Let me know what year, hours and whatnot.
07DominatorSS is offline
Old 12-25-2011 | 10:14 AM
the sellers keeping the ilmores,whats the diffences ,my going to see the boat mon.I dont want to get into a mess. He wants to install 502 procharged motors fully dressed with motor mounts an all
Old 12-25-2011 | 11:55 AM
The Ilmors I know are a lot lower profile, so I'm almost positive the exhaust holes will have to be moved and I believe the motor mounts are different. Your best bet would be contact Ian at Ilmor, ilmordude on here.
Old 12-25-2011 | 03:22 PM
Default fixx
the exhaust holes can be plugged and moved,on a side by side set up with BBC just make sure the crankshaft center line from port to starboard engine is 34 1/2 ''..measure this at the gimbal bearings or if he put the drives on you can get a better reading at the drives input shafts..more is ok but less the exhaust manifolds will rub...
FIXX is offline
Old 12-25-2011 | 06:21 PM
If this is the one down on Lake Cumberland, i have talked to the owner. this boat had Merc power originally and the Ilmor exhaust was modified to fit. the 502s should drop right in
snapmorgan is offline
Old 12-25-2011 | 06:25 PM
yes its the one in cumberlin lake
