Superchargers...Whipple 4.0 or 5.0 vs Roots 14-71
#42
Kaama, you want a super smooth idle with 14-71's and dual 4bbl dominators???? What you will end up doing is shortchanging your top end hp by using a comprimised cam design in search of the kinda idle I know that you are looking for, the 70's came and went, BUY EFI, Smitty
#44
Hey Mark, I dont think you will be dissapointed in the carbed roots setup.
My buddy built a set of blower engines last year, 509CI, 238/248 112LSA cams, 8-71 mooneyhams, superchiller intercoolers. Engines dynoed about 800HP and 800FT lbs give or take a few. Idles good, no plug fouling or stalling around the dock.
I ran almost the same cam as him ,in my smaller 460CI engines, 250 blowers with single dominator. Intially i had them setup with 12* base timing, and a 18* advance. They would puke when put into gear cold. Locked them at 30*, much better. Idle all day, no fouled plugs, no stalling.
From what ive seen, if properly tuned setup, the supercharged setup seems to idle/start better than the same setup N/A. Fire up with a slight blip of the key.
Granted you'll have larger blowers, and larger carbs, but also larger engines.
#45
I had the 532" 14-71 with EFI. Solid roller. Dart Pro1. Great engine by JC Performance. But we had some brain failure once and runned it on low octan... Since we had the new build 572ci 4.2L screw the 532ci engine went to a new owner in Finland.
I know the tech guys here got lot knowledge and will put you in the right direction. But I have to say the 14-71 roots was a real hardcore blower
Mange
The 572ci/1095hp and the JC 532ci/930hp
Mange
#46
Kaama, I didn't take offense at all. I thought maybe you knew something I didn't. As far as the bigger head is concerned it has a 2.35 intake in it whereas the 357 has a 2.30. I have been told that valve is good for a few more hp. So, I thought if I could step up why not?
#47
they were alright,made 1066hp,1076tq at a correction factor of .98%.we want a solid 1200hp,so a head change is in order,plus a better cam.
#49
Ok, wasn't sure I was reading you right. And as far as me knowing something you didn't---hey, I'm still in the classroom with a learning curve on much of this blower and head stuff.
