3300 cable ends for kiekhaefer controls
I made some using using 3/16" heim joints with a 10/32" thread. I can get you some pics if you need a visual. The pin can be punched out, grind a little bit on the inner part of the control away for clearance, insert the heim joint and replace pin. Then put the cables on, then you run them through the boat. I was going to post this in the DIY on a budget form.
I used something like this. You can get them on ebay for $2ea.
http://pitstopusa.com/c-133383-rod-e...-rod-ends.html
