AMS Oil Marine Gear Lube (AGM) Phase Separation?
Have you ever noticed that it changes color significantly after it’s been opened? If you leave a quart unopened on a shelf next to a quart that has been opened you will see that the open quart is about 3 shades darker than the unopened bottle.
Further, small wax-like chunks and settlement form and sit on the bottom of the bottle. If you shake it up well and stand it upside down, this is what forms in the cap after draining.
It’s almost like some of the components are separating. Just curious.
But the stuff in my cap or left at bottom of open quart of oil is totally like a grease type consistency.
I'm not using the proper terminology but it's clear to me that every bottle i've left stored after opening does separate or settle to some degree.
I wondered if it was the additive package which could "weigh more" than the oil it was mixed in....?????
I dunno.
I had two unopened bottles sitting on my shelf this fall that were about 5 - 6 years old. Even unopened they turned a darker color than the new oil we purchased in October in a 5 gallon pail. This same darkening occured in some older 75W90 Severe Gear I have on the shelf. Again, unopened. I've not seen the waxy material in your pics above in any open bottles of Amsoil gear lube that I have.
In 5-6 years, the formula of the product could of changed and the new additive is a different color than what was used.
This could account for color change in new unopened product.
In opened product, the darker color could come from oil oxidation with the air.
This is one reason you should change your oil even if you don't have any time on it.
Ken
Ken
Ken,
We are low hour users but we do use quality oil/lubes. How often would you recommend that a synthetic 20-50w oil (or gear lube) be changed based on time only? For a 2+ case oil change @ $10+ qt you hate to waste...but not compared to premature wear.
Ben
Ben
This is one reason you should change your oil even if you don't have ay time on it.
Ken
Ken
