T&D Machine vs Jessel rocker shaft mont kit >
Old 01-10-2012 | 08:53 PM
Default T&D Machine vs Jessel rocker shaft mont kit
I am looking to equip my new aluminum head on shaft mount roller rocker.
I want some advise and preference before buying between T&D Machine vs Jessel shaft mont rocker kit.
supermx96 is offline
Old 01-10-2012 | 09:07 PM
byrideroffshore's Avatar
Originally Posted by supermx96
I am looking to equip my new aluminum head on shaft mont roller rocker.
Run the Crower Stainless steel stuff. Holds up better. Or use the Steel stuf even better.
byrideroffshore is offline
Old 01-10-2012 | 10:06 PM
GPM
Crower Stainless shaft rockers
GPM is offline
Old 01-11-2012 | 01:59 PM
Crower Stainless shaft rockers had them on my dart pro1 heads they were to small. . i went with jessels. i like the crowers but the set i had were for stock heads. my engine builder told me the jessel will be better so far my motor is running good. so just make shore when you buy your new rockers tell them what heads you are useing
bajabob is offline
Old 01-11-2012 | 02:06 PM
We've used Jesel for many years on our road race engines with zero problems, Daytona 24 hour, World Challenge, Grand Am, blah blah. I don't have any experience with T&D.
RdRacerZ28 is offline
Old 01-11-2012 | 02:55 PM
I used TD and opted for steel rocker with built in spring oilers with zero problems @ 6400rpms
goebel1 is offline
Old 01-11-2012 | 02:59 PM
GPM
The T&D I've run need something rebuilt every season. The rockers keep breaking on my brother's Jesel set up.
GPM is offline
Old 01-11-2012 | 04:03 PM
What spring rate and how much lift to get problem with them?
What did you need to rebuilt every season on the T&D?
Old 01-11-2012 | 04:34 PM
GPM
They are both solid roller application, both cams around .750 lift. The T&D was bearing issues, Crower 68848 springs high pressure, but supposed to be built for them. The Jesels were run with Crower 68806 springs, from memory 265 @ seat 725 open. I don't think either product could be considered bad, I just think stainless is stronger, they both may sell the stainless set ups now, no clue how their pricing compares to Crower.
GPM is offline
Old 01-11-2012 | 04:35 PM
PROWRENCH's Avatar
Ran jesel on my 9000 rpm 522 bbc in my mud racing days. Zero issues.
PROWRENCH is offline
