Pre-Oiler
Anyone using a pre oil system on their 496 h.o.? Necissary, not necessary, pros, cons?
If your the engine sits for very long periods of time this is a viable accessory but not really a necessary item. If you're starting engine after long periods of storage then unplug the coil pack harnesses , the fuel injector harness plug and remove the oil filter, fill with some oil and screw it back on quickly. Then crank the engine over for a series of 15 second burts, maybe 4 or 5 to build oil pressure then connect the harnesses, fire it up and watch oil pressure carefully for first minute or so.
If you are storing the engine for a long period of time over 2-3months especially in wet, humid or cold climates its a good idea to remove the sparkplugs, fog each cylinder while cranking the engine over and then install the plugs and store away. These are storage and refire lubrication options for storage of 3-6 months. If you are storing well beyond these periods then there are other things you should do. Best Regards, Ray @ Raylar |
i live in ny its in storage now, but once it comes out, i hope that im using it at least once a week on the weekend. tips???
any tips on how to make it louder???? i have the above water and long tips off the transom. i hear your the man Raylar for the 496
Originally Posted by BIGBREW
(Post 3598744)
If you want it really loud, no matter if you do a Raylar upgrade or not, then there is nothing that rivals a dry to the tips exhaust system. There is not much that will pizz off as many folks either, just have that in mind. |
Ray,
What if I had an oil filter modified with a fill cap on top? If I had a rubber stopper that I could remove, fill the oil filter to the brim and then turn over, would that be if benefit for spring start up? I figure I could have someone else start the motor, and I'd stand over the oil filter applying pressure to the rubber plug to ensure it stays in. Just brainstorming. I hate spring startup knowing everything is relatively dry. |
Sydwayz:
I think modifying the thin case of an oil filter may be the issue. You could just put a T-fitting under the oil filter adaptor on the return to block side and pour oil into a taller than engine height hose until the oil to block adaptor areas have some oil in them, then plug the T and crank the engine to get some oil system pressure delivery then fire the engine and watch the pressure carefully. This won't fill the filter but some oil in the system will allow the oil pump to prime and then when you crank the engine without fire it should build pressure in the system and deliver some fresh oil to the bearings, oil pump, oil filter, and camshaft oil galleys. Obviously keep a new first time fired engine at idle until the oil can get to all the other places it needs to be like, valve train, camshaft lobes, rockers, cylinder walls, etc. Best Regards, Ray @ Raylar |
Well i have done some reading about dry exaust, though i would like mine to be a bit louder, i dont think i want to be obnoxious. I love these fourms because I can ask these questions and I feel like I get good answers. Just got the boat in October so these fourms keep me busy while im waiting for the winter to pass by, I am interested in what the guys above were curious about also, the first start for the spring. What is the best way to go about getting some oil moving before starting the motor?? Again thank you for your time and information.
BIGBREW:
Understand your love of a loud exhaust, but be careful here with dry exhaust as many areas now or in the near future have noise regs and enforcement that tickets and forces many performance boaters to quiet instead of "louding" their exhausts. Also keep in mind stock 496HO's don't have big camshafts in them that give the loppey rumble that some performance boaters want and it takes power to make that rumble and noise so maybe you'll have to up the power of the engine to get the added 'loud" and the extra benefit of more boat speed and performance is a nice secondary benefit! Best Regards, Ray @ Raylar |
Lubrication prior to firing up the motor is important. Ray points to the length of time being very important.
IMHO the best system for engine pre-lube. 20 lbs. of near instant pressure. Leave it "on" while you fire it up. Besides that, a great and easy way to change the oil with the quick connects that come with the kit. Yeah, I know it's pricey. Com'on, isn't your motor worth it??????? http://www.keitheickert.com/p-12473-...er-system.aspx |
I have a Masterlube accumulator on my boat, and I love it. I use it for pre-oiling and as an accumulator when I'm in really rough water, it helps prevent pump cavitation. After spending over $10k on rebuilding my motor, it's cheap insurance.
Originally Posted by ThisIsLivin
(Post 3599897)
I wanna see the post that comes after "I was holding the rubber plug in and....."
So what would be an inexpensive, yet effective way of pre oilimg the motor before a post winter start up. Pull all the spark plugs and put a squirt of oil in the cylinder? Maybe un-plugging the cpu and turning the motor over to build some pressure?
Originally Posted by 1 MAIDEN AMERICA
(Post 3599959)
Originally Posted by UrbanDisturbance
(Post 3599937)
My Masterlube does not work like it used to. Even when it is empty, it reads 30lbs of pressure. It worked very well for about 5 years. I would try the one with the electric motor. After the accumulator is empty on the Masterlube, that's it. You can't get oil back into it until the engine starts. When you change your engine oil with the Masterlube installed, a lot of old oil is still in the accumulator. You would have to drain those manually, fill them back up half way, then re-pressure it up to 80 PSI. My engines are being redone and I am debating to put the Masterlube back on. I would just crank the engine without starting it to get oil circulating.
Made my on pre-luber/oil change pump set up.
Used poly bodied triple diaphragm pump (Grainger) with built in pressure switch (20 psi on to 40 pis off), piped it into the lines with a check valve so that when the engine oil pump kicks in, it shuts the check valve (the pump has it's own check valve but I want double protection). Boat sits for sometimes 4 weeks, just switch the pump on for a couple of minutes, turn key switch to "on", watch oil pressure gauge cycle between 20 to 40, bump the starter to rotate cam and close valves that were open and open valves that were closed so all the lifters get pumped up. Let it sit for another minute or two, then start it up! little to no lifter noise, engine oil pump builds to real pressure, then I just switch off the pre-lube pump. Since pumps are not CG approved, have them mounted under rear bench and 1/2 inch oil lines running back to the engines. Put in quick connect fitting on discharge side of each line and oil changes are rapid. |
(Post 3599937)
So just unplug the main cpu and bump the motor a few times?
Originally Posted by TexomaPowerboater
(Post 3600386)
+1
$700 with no end fittings. Too much. Others for less
Email me, I have very good info on these units - accumulator style work fine for pressurizing the engine.
[email protected] Kirk |
BigBrew, if you want louder just ride behind me all summer, not like your gonna have a choice anyway....:evilb:
You bought a nice boat, now just enjoy it! |
there is a kit advertised in the classifieds that seems reasonably priced...any feedback?
Originally Posted by Raylar
(Post 3598632)
There is always this. Would require some plumbing. But you could prelube in seconds.
http://www.petersonfluidsys.com/filter_mount.html |
My boats (4 total over a 15 + year period and @ 1,000 hours combined use) get laid up at the end of October/first of November and pulled back out March/April. I back them down the ramp, turn the key, and fire them up. They always build oil pressure immediately and I have never heard a bearing knock or lifter/rocker arm rattle after starting them. I've always used Mobil 1 15W50. Any wear caused by starting an engine without pre-oiling after a 4-5 month layup has to be so nominal that you'll never notice the difference over the life of your motor.
| All times are GMT -5. The time now is 04:43 PM. |
