-   -   Bravo 1 or Speedmaster A (https://www.offshoreonly.com/forums/general-q/270011-bravo-1-speedmaster.html)
FIXX 02-04-2012 03:22 PM
fixx
Originally Posted by MILD THUNDER (Post 3609523)
3A parts are around. Gears are still being manufactured. Seals and bearings are nothing exotic. Props a bit more money, but still can sometimes be found reasonable.Bravo and 3A not even in the same league. MUCH stronger drive, and much stronger gimbal ring and what not. If you plan on running some big power, go for the 3A. As long as the engine is reliable, you'll be boating and not breaking.
+1 and the azz of your boat will look like a fountain when sitting still :thankyouthankyou:
A.O. Razor 02-04-2012 03:25 PM
Also, the cleaver props are better technology than the bravo props. The surface props are also way more efficient than the bravo props. Hydrodynamic drag on the ĶIIA is also less. You should consider looking into a SSM#V as well. The shorter x-dim makes it easier to install than the IIIA. To get the prop high, you'll need to mount the motor fairly high with the IIIA. But if the room is there, not much of a deal.
682gold 02-04-2012 04:17 PM
Ok what is a fair price for the Speedmaster 3a w/ tranny and about 5 props. Speedy is a left hand drive and is in good shape.
