edelbrock alum head opinion
hi all in the process of rebuilding my old 454, stroking it and have a chance to get a set of these heads at a good price(new, but never used) - any feed back, pros or cons....dont have the flow # yet from seller but should soon
thanks pat
thanks pat
i have installed them on several marine engines,they are better than stock gm heads and with aluminum,you can rwn more compression,because aluminum dissipater heat much better than cast iorn.they also flow way better than stock gm heads,and they are priced right.i say go for them.
They don't like salt water on a Gen V VI block, Water passages will not line up ( round hole on the head , oblong hole on the block ) salt water sits on top of head gasket and eats up uncoated alum.
bottom line is ,no bare aluminum head likes salt water,no matter what block they are on.
