Bennett Tab Control ???? >
Old 06-20-2002 | 02:57 PM
mxz800's Avatar
Default Bennett Tab Control ????
for those of us that use bennett trim tabs which style control do you use and do you use an indicator? i have what i believe is what they refer to as competition style control (has four seperate buttons not rocker swithch) and i hate it. has anyone else had better luck with the rocker or joystick control?? Also anyone had any luck with indicators other than the mechanical cable type. just not in the mood to cut my dash or transom for the mechanical indicators yet.
Thanx Rob
mxz800 is offline
Old 06-20-2002 | 03:06 PM
formula31's Avatar
I use the rockers and the Bennet trimdicators (new this year) so far so good on them. I dont have any problems with the rockers but I am going to figure out a way to use them from my steering wheel. Heres a picture of where I mounted the trimdicators.
formula31 is offline
Old 06-20-2002 | 03:11 PM
mxz800's Avatar
formula 31 if that is your rockers behind the wheel looks like and awkward place to have em. also do you have any problem reading your trimdicators in the sun. are they the style with the digital readout and the bar graph and how did they tie into your system??
mxz800 is offline
Old 06-20-2002 | 03:30 PM
HiPerf2000's Avatar
I have the same tab/indicator setup as formula31. Mine came from the factory like that, so I'm not sure exactly how mine tie in.
But i don't have any problems seeing them in the sunlight.
HiPerf2000 is offline
Old 06-20-2002 | 04:18 PM
formula31's Avatar
Yes, the rocker location sucks (OEM). The readout is very bright and has the bar and the numbers (0-20) I have the whole Bennett system with twin cylinders driving 280 k-planes (Frankentabs as somebody called them). The trimdicators come with the senders that are in new cylinder tops. You just change the tops and run the wire. And then mount the cpu, calibration is easy and away they go. It was a nice kit.
Old 06-20-2002 | 04:20 PM
formula31's Avatar
Im actually working on a way to use the same senders and indicators on my drives.
Old 06-20-2002 | 04:44 PM
hauling ass-a
I have had both in the past, my new formula came with rockers and they are alot easier to use.
Old 06-20-2002 | 06:03 PM
mxz800's Avatar
thanx guys the rocker switch is happening tommorow i think the trimdicator install is next week
Rob
mxz800 is offline
Old 06-20-2002 | 06:04 PM
mxz800's Avatar
do you guys know if the trimdicator comes with a white housing or just the dark color??
Rob
mxz800 is offline
Old 06-20-2002 | 06:20 PM
Frequency's Avatar
They better not come in white!
Frequency is offline
