Teague Switchable muffler question
I have two sets of Teague switchable mufflers. I need to install a relay for the solenoids. Can anyone make a suggestion as to what to use? Would one be enough for all four mufflers or should I use one per set?
Charter Member#157
I would get the soleniod from Teague. Pricey! Last one I bought was over 4 years ago and it was like $60
It is basically a marinized Ford starter soleniod. But more heavy duty!
I have 2 pairs on my boat and one went out. Tried one from Napa and it only lasted a couple trips out.
Bought the correct one from Teague and it has been there for a few years.
OOPSSy, you need a relay, I was thinking Soleniod. Sorry
This Cat is trying to keep up with the Big Dogs
PF Marine
bought one from Teague runs all 4,, use heavy ga. wire good solder fittings and it will last. I've had for 4 years.
Charter Member#157
I would say 95% of the time i leave them closed.
I still have the y-pipe in mine from the original diverters.
I just removed the internals and welded the holes.
I still get the flow out the transom with some diverted down the pipes. I feel this really helps keep the main bark off the noise but still allows some pressure relief
Typically they do not bother me all that much, but then agian I really have not had much time in the boat in the last several years.
