6.2 383 cranksaft >
6.2 383 cranksaft
6.2 383 cranksaft
Old 02-18-2012 | 12:52 PM
Default 6.2 383 cranksaft
Which crank would you use,
Stock Merc 6.2 crank, Are these internally balanced?
Or Scat cast crank?
Trying to start collecting parts.
Thanks for your input.
CC230 is offline
Old 02-18-2012 | 01:27 PM
Default Fixx
if its a budget engine look into the scat f43 light weight crank..
http://www.scatcrankshafts.com/press_releases/F-43.html
if your going for a all out stout crank then winberg..
http://winbergcrankshafts.com/
FIXX is offline
Old 02-18-2012 | 04:15 PM
so, avoid the eagle stuff?
dereknkathy is offline
Old 02-19-2012 | 12:15 AM
Wink
Just my opinion. For the nominal difference in cost bewteen a 383 SBC cast or forged crankshaft I think you are way ahead staying with the forged crankshaft as a base building block of your new planned engine.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 02-19-2012 | 11:23 AM
The stock 6.2 crank is a nice forged piece. Originally made by Lunati, but not sure on the later engines. They are internally balanced. If you have one of those, keep it. Otherwise spend the money on a quaility forged crank.
Bob Lloyd
Full Throttle Marine
Or Scat cast crank?
bobl is offline
Old 02-19-2012 | 01:27 PM
Thanks Bob and Ray, thats what I needed!
CC230 is offline
Old 02-20-2012 | 06:47 AM
The later (6.2 Horizon) is not a good unit. I had one break in half at 4200 RPM in a pleasure boat. Engine was never apart and was not a hi performance boat running hard. When we took it to the local crank shop the owner said he had seen several like it.
Good parts make good engines!
Steve
smiklos@sunprint is offline
Old 02-20-2012 | 11:29 AM
Interesting.
CC230 is offline
Old 02-20-2012 | 11:38 AM
Question
Steve
Miklos, I have 6.2 MPI's with over 200 hrs on them. They're 2003 models.I think they have the forged cranks.What year was the one you had issues with?
Thanks,
Attila
spectras only is offline
Old 02-20-2012 | 12:07 PM
On top of that,,,what is the difference between Horizon and Mercury, did a search no info that I could find. This thread is turning out to be very informative IMO.
CC230 is offline
