Best Timing
Old 06-21-2002 | 01:19 PM
ROLNTHUNDER
Default Best Timing
What do you think the best timing for a stock 92 502 carb should be set at to get best performance..
Old 06-21-2002 | 02:25 PM
Should be set at 32-34 degrees.
Griff is offline
Old 06-21-2002 | 02:28 PM
Should have said that's total advance which comes in at about 3500 rpms. Base timing would be 8-10 degrees most likely.
Griff is offline
Old 06-21-2002 | 02:41 PM
ROLNTHUNDER
Thanks, i was going to bump it up to 10 deg as a base so the total should be at 34@3500.
Old 04-18-2004 | 06:36 PM
ttt
HPJunkie is offline
articfriends
13
01-07-2009 03:00 AM
tomas_wallin
7
05-26-2005 02:06 AM
trobertsuk
5
03-09-2004 06:22 PM
34scarab
9
10-23-2003 10:20 AM
bajah2x105
Baja
0
09-10-2002 05:51 PM
