Intake screen for 575sci blower?
Stupid question (I ask a lot of these)
Looking for extra protection for my engine in the event of a supercharger failure. Things I think I already know -The early 575sci super chargers are know for coming apart -Chillers add some protection for these parts falling into the engine -Many have swapped out the blowers or added chargers -The chillers may cause complitcations with pooling, and of course complicate the set up These engines are 2002 models with zero run time since new. Does someone make a screen that goes in-between the blower and the intake? I would like to run it stock for a while before chillers, just looking for some extra protection. I do plan on removing the blowers, checking for drag and changing the 10 year old oil. Thanks |
just pull them off and have them rebuilt/checked...not worth chancing a 20k or more engine rebuild to rebuild the blowers for $1500.
The earlier blowers were actually the better style of the two though. -If you don't mind...what's the story on a 02, with no run time either of the engines? |
Call Ron Hayes @ The Blower Shop. And yes the older ones are much better.
Originally Posted by triple 300s
(Post 3624596)
The earlier blowers were actually the better style of the two though. -If you don't mind...what's the story on a 02, with no run time either of the engines? So the older blowers are actually better? Rebuild or not I still want a screen. I remember seeing a screen gasket for a 6/71 years ago |
Originally Posted by Advantage 575
(Post 3624604)
I have an '02 with the W on the side and reservoirs front and rear.
Are these the better blowers? I haven't had a failure but I did replace the bearings at 150 hours or so. I was also able to squeeze in an extra seal on the two rear seal/bearing areas. About $100 in parts for both blowers. I'm getting ready to rebuild again and have looked into ceramic bearings. What do you think of them? I change the oil every 50 hours and it always looks good. I've been using the recommended Bravo HP gear oil. What do you think about switching to Torco? |
The B&M's have sealed ball bearings in the rear, I've heard
of more issues with them failing than problems with the Weiands. |
Originally Posted by 1 MAIDEN AMERICA
(Post 3625135)
Not trying to be a smart azz but if a blower starts to come apart do you really think a piece of screen is going to stop the pieces ? I would think if it got that bad I would take the engines apart any way . Just my .02
Originally Posted by Jeff P31
(Post 3625497)
Guess I am just paranoid after searching 575sci on this site, hooror stories. Ill just run em |
| All times are GMT -5. The time now is 08:18 AM. |
