Leaking Polylift >
Leaking Polylift
Leaking Polylift
Old 02-28-2012 | 02:05 PM
Mentalpause's Avatar
Originally Posted by deboatmon
It was never my intention that this post unload on Poly Lift, as I did and still do believe they make a great lift. But, the truth is not always pleasant. Poly Lift has opportunities to make things a little better and easier to accept if they choose to go down that road. The truth is that their guarantee clearly states the terms of the warranty they provide. But, I do believe the intentions of the statement "lifetime warranty" are, at the very least, misleading to imply that they will repair it free for life to the original owner. There's nothing free about it. To build upon the statement of a lifetime warranty while knowing full well what it takes to actually effect that warranty could be considered as misleading. What would be really nice is if they, Poly Lift, like many other manufacturers have already done, accept that sometimes things happen and they could offer to help with advice, connections to others in the area they might know that could help, or something positive in general.
As I said, I will find a way to fix this very small leak and will likely do so without the help of Poly Lift. That is, unless Poly Lift wants to chime in on this forum and offer some good advice or suggestions for their product to a very valuable and good customer base.
I'm not unloading on their product. I still believe it is the best or at least in the top echelon of products available. But the attitude of the owners has changed since Mark took over from his dad, and their service has suffered, regardless of how their warranty reads.
Mentalpause is offline
Old 02-28-2012 | 02:19 PM
does your Marina have a welder ? or local shop to put the toon on a trailer and have them burn a bead .sounds like more aggravation then its worth
Pot of Gold is offline
Old 02-28-2012 | 02:56 PM
Default Poly Lift
Yes, my marina has a welder. But they don't have a welder that welds high density polyethylene and that's what Poly Lifts pontoons are made of. They are not metal, they are 100% synthetic. They are pretty much indestructible.
That is, except for a little tiny leak every now and then.
Mentalpause, I didn't mean to imply that you were unloading on Poly Lift, but rather that it was not my intention to unload on them through this forum.
I appreciate all the input.
deboatmon is offline
