6.2 Rod size >
6.2 Rod size
6.2 Rod size
Old 02-28-2012 | 11:42 AM
Default 6.2 Rod size
So which rod size did Merc actually use in the 6.2?
CC230 is offline
Old 02-28-2012 | 05:47 PM
Anybody ever have one apart???
5.7 or 6.0 rod length, just curious what they chose to use.
CC230 is offline
Old 02-28-2012 | 06:23 PM
i googled 6.2 merc con rod. got a parts breakdown. actually several. rod is listed as 5.7 magnum. the 6 inch rod is strictly aftermarket. and longer rods make more power and less torque. they are for higther rpm applications. so, i will bet they are 5.7 length. i am almost surprised they didn't use 5.565 rods from orig 400's.
dereknkathy is offline
Old 02-28-2012 | 06:43 PM
I googled it also and got a different part #, that's what got me thinking.
CC230 is offline
Old 02-28-2012 | 10:47 PM
longer rods make more power and less torque,do you realize what you just said?
mike tkach is offline
Old 02-29-2012 | 05:13 AM
shorter rods do increase torque. at the cost of extra side loads on pistons.
Old 02-29-2012 | 06:02 AM
Both rods with that stroke increase side load on the piston, but a 6" rod creates a greater side load than a 5.7".
Anyways, I could see Mercury using the 5.7 rod since thats what the use in the 350's. Less parts to have to inventory.
CC230 is offline
Old 02-29-2012 | 07:01 AM
It's the other way around. A longer rod creates less cylinder wall load, since the rod angle is less with the longer rod. The shorter the rod, the more angle and therefore more wall pressure. A Problem then can be that a long rod needs less compression height, which in turn makes for a shorter less stable piston.
A.O. Razor is offline
Old 02-29-2012 | 07:38 AM
Some of the longest rods I have seen are in tractors.....some of the shortest are in high reving little 4 cyl. engines. What is the logic behind shorter rods making the most torque?
4bus is offline
Old 02-29-2012 | 09:24 AM
you are correct,thr longer rod will lessen the side loading of the piston against the wall,that will reduce wear on the piston&wall.
