-   -   496 Mag Serpentine Belt debris (https://www.offshoreonly.com/forums/general-q/271705-496-mag-serpentine-belt-debris.html)
steeler885048 10-26-2020 12:17 PM
Was also curious if
Baja Dan or SDFever had a significant reduction in dust or elimination...
FBRONCO 03-05-2021 10:51 AM
I ordered all the parts that will be needed and they arrived!
Parts:
10-8M0103813 SCREW (M8 x 30) QTY 2 (Holds tensioner pulley)
10-8M0103817 SCREW (M8 x 60) QTY 1 (Alternator bolt)
10-4010820 SCREW (M10 x 20) QTY 2 (secures tesioner)
37-865748 DECAL (Belt route)
57-865635Q01 BELT
865594T01 ALTERNATOR BRACKET
865596T01 TENSIONER BRACKET
865597T TENSIONER
865777 TENSIONER PULLEY
8M0131223 POWER STEERING PUMP BRACKET
You can reuse your other bolts. You may have to cut 10mm off of your old power steering bracket bolts. This cost me about $450 per motor. I plan on installing in April.
