Brodix head
Old 03-07-2012 | 04:40 PM
  #31
actually the REAL oval port from the 781 head and all the 396's from bygone eras are the standard oval port. when it became a truck only motor they dreamed up this tiny little round thing and called it SMALL oval port. the orig ovals are nearly as big as rectangle ports and are good for 600+ hp with 2.19 valves and some porting. of course, you can get 500 out of the peanut port head with LOTS of porting.
dereknkathy is offline
Old 03-07-2012 | 05:44 PM
  #32
Originally Posted by HaxbySpeed
Rectoval
sounds like rear-end medicine....
pqjack is offline
Old 03-07-2012 | 06:24 PM
  #33
Turn your head and cough..
HaxbySpeed is offline
Old 03-07-2012 | 06:25 PM
  #34
Oh chit.. here we go again..
Old 03-07-2012 | 06:44 PM
  #35
Better get out the toast so you can spread that peanut butter!
endeavour32 is offline
Old 03-08-2012 | 07:47 AM
  #36
Default Chit
I like it when the chit starts!
Thunderstruck27 is offline
Old 03-08-2012 | 11:07 AM
  #37
Haxbyspeed, This sounds like that guy that came over from some car site and was making very tall claims backed by HIS further dyno claims. What was that jomoc's name?
ROTAX454 is offline
Old 03-08-2012 | 11:38 AM
  #38
Are we talking about someone mentioned in this little thread? Isn't Cstraub the "king" of peanut heads and bad cams?
http://www.offshoreonly.com/forums/g...-colorado.html
A.O. Razor is offline
Old 03-08-2012 | 05:46 PM
  #39
Getting this thread back on track, Hey Paintman, what is the latest?
ROTAX454 is offline
Old 03-10-2012 | 07:14 PM
  #40
Might wanna give a phone call to JIMV on the board here. He has a new aluminum casting that is supposed to flow [email protected] lift. Im pretty sure Jim has always been into the smaller runner, high velocity type of heads, which just may be the ticket with a engine of your size to make some nice power.
However, if 500-525HP is your goal, I dont think you'd have a problem using any of the mentioned heads with the 498CI and a good roller cam. Well, maybe except for the circus peanuts!
MILD THUNDER is offline
