Brodix head
Hi all
Just letting lookingfor thoughts on brodix alum oval port heads. Thought I had set of edelbrocks but that deal fell through. Where do the brodix rate? Thanks pat |
Brodix are top of the line heads together with Dart and AFR. Not sure I understand what you mean by where do they rate. Quality, price?
Which heads are you looking for? |
Hey razor,
Looking for quality, and it sounds like I'm the right track. I will get the part info out shortly. Thanks |
Originally Posted by paintman
(Post 3633731)
Hey razor,
(Post 3633731)
Hey razor,
Looking for quality, and it sounds like I'm the right track. I will get the part info out shortly. Thanks Oh yes, you are on the right track. Some builders prefer Dart over Brodix or AFR and vice verse also depending on application. You are in good hands with Brodix. They are in a different league than Edelbrock. Depending on what you are looking for, also take a look at the AFR heads and the Dart heads. |
Brodix, Dart, great heads. Check with your engine builder for oval vs. rectang ports.
Fresh water or salt? Recommend closed cooling with salt water. Wannabe |
Builder is going to go with oval port heads and engine started life as 454, currently its bored .60 over he's going to take it another .10 over. Going to go full roller, scat crank, holley 850 marine carb, msds.
Also I'm going to paste some comments from builder below "my*intrest was in the uncoated components. we discussed corrosion. key is a quality electrical ground system for the motor when installed in the boat. also the fogging system is well worth the effort" I haven't seen many discussions on elec ground system. He is also going to add some slick kind of fogging system to engine. And finally its a fresh water envir. |
Might think about a stroker if you're buying a crank.
Originally Posted by GPM
(Post 3633847)
X3...Forgot to put that in yes we are strokin it.
:eekdrop:
Originally Posted by HaxbySpeed
(Post 3633854)
x2
