Best place to install a oil temp gauge?
I just ordered a Gaffrig oil temp guage and was wondering where to mount the sender? Before or after the oil cooler? Can I mount it on my remote oil filter mount as I have 2 extra ports on it??
Thanks, Ken |
Good question, sending this back to the top as I'd like to know also.
I suggest you mount the sender after the cooler, make sure your temp pickup is in the oil flow stream for best reading.
In the oil pan. Doug
ON THE DASH WHERE YOU CAN SEE IT :D
After the cooler in the remote oil filter.
In the pan only tells you the temp of the oil in the pan. The more critical reading is oil temp going to the bearings. If you don't know the temp going to the bearings how do you know your cooler is working at all or working too well? How do you know you're getting proper viscocity flow? How do you know water is not condencing back into the oil, instead of being boiled away? oil temp should be 212 min, 220 idealy and 270 is too hot. DAVE |
In the pan. You want to know the max temp of your oil.
Gen V has a bung on the port side of the pan. Second choice would be at the remote oil filter housing (if it is BEFORE the cooler where is should be) |
| All times are GMT -5. The time now is 07:34 AM. |
