Anchor question >
Anchor question
Anchor question
Old 03-21-2012 | 07:53 AM
I not only shortened the stock (C), but also the shank (B) so as to get a larger anchor (flukes) in my anchor locker. I use about 6 feet of chain rode on the shank and have had zero set problems with this modification. You will be fine.
Dan
BajaDan is offline
Old 03-21-2012 | 09:02 AM
West Marine sells Manson Racing anchors in all sizes that work great and store easily. They have a shortened (C) and protective plastic balls on the end that are great w/ protecting fiberglass bringing them in. I use the R5 for my 38 Lightning and have not had an issue w/ it.
38 GoFast is offline
Old 03-21-2012 | 09:20 AM
The cross bar helps with setting and more importantly stability/keeping the anchor set in changing wind direction or current conditions.
Trimming an inch or two total will probably not have a big impact for a day time, lake boater.
If you boat in a tidal area or frequently overnight where changing winds might give you a scary wakeup call, I would keep it as long as possible.
We frequently overnight on the hook. The best way to get a good night's sleep is with a significantly oversized anchor which takes the worry away. Also great for locking down a raft up line so boats are not moving and resetting.
FX-37 gets the job done and breaks down for easy storage
ChargeIt is offline
Old 03-21-2012 | 09:31 AM
Sydwayz's Avatar
Forum Regulator
I too lopped 1.5" off each side of stock on my old Fortress. It worked fine, for a Fortress.
Do yourself a favor though, and buy a Box Anchor first. You can get them from West Marine now. Just return it if you don't like it, but I guarantee you won't return it!
Sydwayz is offline
Old 03-21-2012 | 10:52 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Sail Boaters uses those extensions to hang their anchor on the railing for storage. Don't be a sail boater.
US1 Fountain is offline
Old 03-21-2012 | 11:35 AM
what i have been doing ,,is keeping the brackets (loose)that hold the stock on,and when iam ready to store anchor i slide the stock to one side,it helps in getting the anchor under seat,,without taking it all apart
TWIN-SPINS is offline
Old 03-21-2012 | 01:18 PM
I like that ball on the stock idea...I think I'll drill out a couple of my brothers golf balls to fit my fortress!
Thunderstruck27 is offline
