Nose cone install
Im putting a set of leading edge low water pick up nose cones on my 2000 bravo 1's,,, after drilling the 1/2" hole in my case for the pickup tube what will actualy hold the tube in place. Any ifo on the install of these cones would be great. Ive heard all metal works good over the epoxy that holds the cone on what are your thoughts. Thanks
I filled the cone with peanut butter consistency epoxy to the rim and pressed it on with the tube in the right spot. Make sure the angle on the cones are the same i.e. tilted up or down the same for both drives.
I use JB Weld and a ratchet strap to hold it on the drive until it sets.
So i guess i should use the cone as a jig to drill the hole in the case and then once it is where i want it jb weld the tube in the cone.
Also should i make it fit over till the upper and lower grove in the cone is all the way back against the case. If so i may need to grind on it to fit it does not go on that far as it is. Thanks Guys.
Originally Posted by rssteiny
(Post 3646666)
Along this subject - i'm repainting my bravo and have a nose cone kicking around
my boats goes 65 mph will a cone add any speed |
Originally Posted by jettdogg
(Post 3646867)
along this subject - i'm repainting my bravo and have a nose cone kicking around
From my experience with outboard motors;
if your drive not high enough to need a low water pickup you will loose speed as the low water pickup has more drag than the stock side pickups. I have run stock side pickup on outboards with the prop shaft about 3-4" below the bottom and still had water pressure. If your boat is not fast enough for the drive to cavitate or blow out the added length of the drive will cause more drag. The biggest gain outside of good props on a lower unit was working the skeg from what I have seen. I think the part of the drive that is deepest in the water is the part with the most drag. |
there are a lot of people who feel the nosecones actually slow the boat down. look at the fronts of the space shuttle, Acela trains, submarines...they all have a rounded shape similar to the front of the stock drives. they stopped putting needle points on supersonic aircraft in the 50's. and they add stress to the steering as they hang out in front of the steering axis...
| All times are GMT -5. The time now is 08:12 PM. |
