Head Gasket
Old 03-28-2012 | 04:28 PM
Sorry for taking so long. He just got back to me today. He has been out with the flu. His price for cometic head gaskets is $70 per side, but his warehouse only stocks the 0.040 gasket. It may be more to have one ordered, but I may be able to have it sent right to your house if I place an order. Let me know if you want me to look into it more.
FWIW - did you ever just consider milling your heads down 0.030-0.050? You wouldn't hurt them at all, you could dial in your cc size, and it's not all that expensive (my machine shop charges $80 for 0.020, and they'll do the next 0.020 for less). You should be able to do some light bowl blending yourself, better protect yourself from detonation issues, and have a more dialed in motor. Just my $0.02...
wjb21ndtown is offline
Old 03-28-2012 | 06:37 PM
The price sounds good. When it gets time to install the heads I'll let you know. As to the machining, I think I am going to have them milled a bit.. I need to CC them and see where I'm at.
Thanks for looking into this for me.
endeavour32 is offline
Old 03-29-2012 | 01:47 AM
A 454Mag has a comp ratio of 8.75:1 and so do the 400, 420, 425. They are all 454's and use the same pistons, head gaskets and heads.
I would just mill the heads .020....in fact that is exactly what I did do with the 454mag I had in my 24 OL.
Griff is offline
Old 03-29-2012 | 06:31 AM
if he mills the heads,should intake also be milled??
TWIN-SPINS is offline
Old 03-29-2012 | 07:06 AM
not for only .020''
pqjack is offline
Old 03-29-2012 | 12:02 PM
For .020, the intake will fit fine and in most cases .030 is fine.
Griff is offline
Old 03-29-2012 | 12:16 PM
Sounds good, thanks guys!
Old 03-29-2012 | 04:09 PM
I believe roughly for every .010 milled you reduce chamber size by 2c. If you milled them .020, you should gain about .25 compression.
MILD THUNDER is offline
Old 03-29-2012 | 09:37 PM
Griff, what kind of performance gains did you get out of this?
Old 03-30-2012 | 01:24 AM
I did a lot of other stuff at the same time also. I did a complete top end with cam, carb, roller rockers, and Imco exhaust. The engine was very similar to Merc 420 when I was done.
I picked up 400-500rpms and about 5-6mph at WOT. Probably gained 60-70hp or so. I figured the milling was maybe good for 10hp.
I gave my specs to somebody else and he dynoed his engine at 425hp at 5000rpms. The only difference was he also changed intakes. I was spinning mine at 5400rpms.
Griff is offline
