Oxygen sensor spacers
I found a set of exhaust manifold/riser spacers that are drilled and tapped for an oxygen sensor. I would like to take the guess work out of tuning my carb and hook up an A/F ratio gauge. Does anybody have any experience with this? Do I need one sensor per manifold or can I run a sensor on just one side? If I do run two sensors, do I need two gauges or can I wire both sensors to one gauge? I am totally dumb in this department and need all the help I can get.
You can do it with just one sensor. You can switch sides just for peace of mind.
FAST has a unit that will read two A/F probes.
P.S. don't leave an unpowered probe in. If you have it installed, you should keep power to it whenever the engine is running.
im thinking now that this wont work for me because im running silent choice and dont think i will have the flexibility to put a spacer in and move the riser up. thanks for all the advice guys, if i decide to do it i wll post results
