Oil temp
I have a 468 N/A With crossover and hose running from crossover to tstat housing 160* tstat .have my oil Temp sender in the extra pipe threaded hole on remote oil filter. What temp should I be seeing? Just cruising around 3000 RPM I am seeing 225* new motor first time out yesterday. I have the cooler bypassed because with cooler hooked up running on water hose was only seeing 100* oil temp. Never ran it in the water with cooler hooked up so can't give you that temp.
Originally Posted by Artate78
(Post 3654187)
X2 Hook up the cooler and try it under load . You will not get much heat in the oil just running it on a hose.
Hey 78 - did you pick up your 923 from Damon?
No he sold it to some punk in hot springs.he had it for a few weeks blowed up the motor patched it back together and then ripped me off. But yes it was Damon's. I have talked to damon a few times. He has been very help full. Do you know him?
Ok what oil temp is to high? And what is to low?
225 is not bad bad, but would seem to be getting close for some. 220 is where we try to keep it, don't let it get to cold, as it will foam up. So IMO and alot of others 220 is about the mark
John jr |
(Post 3654869)
280* = way too hot and the oil will start breaking down The oil should get to at least 210* cruising in the 3000-4000 rpm range to burn off condensation. |
The Mercury Racing 525 service manual says max oil temperature is 220*F. Hook up your cooler.........
| All times are GMT -5. The time now is 11:24 AM. |
