-   -   running circulation pump w/o water (https://www.offshoreonly.com/forums/general-q/273766-running-circulation-pump-w-o-water.html)
tnc110 04-04-2012 10:32 AM
3 times last season i got junk in my water intake and got motor up to to buzzer temp.
I replaced the seawater pump, but didnt know what effect this would have on the circ pump..
How long can the circ pump run dry?
roughwater 04-04-2012 10:51 AM
i think your fine, if your refering to the actual eng water pump on front of the engine there is no rubber parts inside to burn up like inside the raw water pump/impeller...
1BIGJIM 04-04-2012 12:05 PM
You still had water in the block so it did not run dry.
It still has a seals.
ThisIsLivin 04-04-2012 01:14 PM
If the seals run dry for any length of time they will start leaking.
mcollinstn 04-05-2012 06:13 PM
Yeah, you can burn the seals, and even scorch the snout bearings.
But if you don't have any water leaking out from behind the pulley, you're good.
MC
Griff 04-06-2012 12:32 AM
As long as no water is dripping out the weep holes, then it is fine.
roughwater 04-06-2012 07:34 AM
^^^^^This...
dereknkathy 04-06-2012 03:50 PM
you would damage more than the circ pump if you got it hot enough and dry enough to do damage to it.
