My v8 won't start with a v6-14 module
Pulled out my v8-24 and swapped in a v6-14. It hit once and tried to start and now it won't do anything but crank. I'm by myself so I haven't been able to check for spark at the coil but im assuming since it hit once there is spark. I've tried pumping and pumping and nothing. Tried holding it wide open and still nothing, any ideas would be great
any reason you didn't use the correct module ?
Originally Posted by stevesxm
(Post 3658260)
try putting the old module back in,if it starts,the v6 module is no good,if it still wont start,something else is wrong.
Originally Posted by mike tkach
(Post 3658275)
Is the module grounded properly????? Both the ground wire and the module case need a good ground or you won't get any spark.
Originally Posted by Griff
(Post 3658475)
Or very weak spark with bad grounding..... |
(Post 3658475)
I bolted it in exactly as the other one came out and the boat ran before I changed modules. Im going to try and clean up the surface of the plate and try to get a better ground. I'll post back results later today.
| All times are GMT -5. The time now is 05:50 AM. |
