Full Power Steering Is Getting Air In It. Why? >
Old 04-08-2012 | 09:18 AM
Default Full Power Steering Is Getting Air In It. Why?
I have Zeiger full dual ram, helm back power steering. It was fine for 2 seasons but at the end of last season I got play in the cylinders and had to bleed it. I was able to get all but about 1/8" of play out of it; It used to be rock solid. Now this spring, the same thing. I bled it repeatedly and was able to get it to about 1/8" of play. Boat ran great several times out. The steering still had about 1/8" play so I figured I'd re-bleed it and be good to go. Now after just sitting out of the water for a couple of weeks I am back to about 1/2" of play in the cylinders. The fluid level has not dropped and does not appear to be overheating or foaming. Any ideas?
thirdchildhood is offline
Old 04-08-2012 | 11:42 AM
BTW, I checked all fittings and hoses. There is a quick connect fitting at the filter though but the o-ring looks good. That is the only connection I can't tighten.
Old 04-09-2012 | 07:42 AM
77 views and not one idea....
Old 04-09-2012 | 07:46 AM
No ideas?
Old 04-09-2012 | 08:07 AM
rv
Did you try Zeiger? The manufacture would be my first point of contact. I have spoke with him in the past and he has been helpful.
rv is offline
Old 04-09-2012 | 08:49 AM
Rookie's Avatar
If you are not actually seeing aerated fluid it just might be a seal in a cylinder or the system. If it is solid while running the engine and and gets play after it sits for a while. It just might bleed by after a bit of time.
Rookie is offline
