GM Flywheel questions
can someone verify this? my 1-piece flywheels don't seem to have any counterweight on-in them.
I bet if you look at it closely you will see a weight molded into the flywheel.
However, there is the possibility that if it is a custom built engine that it is completely internal balance with no weight on the flywheel.
Trying to figure out if i can use the standard or manual flywheel or the automatic flywheel seems to be to thin compared to the old one i took out which is a 12inch version an it was a 82 350 an im replacing motor with a 97 350
