-   -   Oil Pan Interferance Problem (https://www.offshoreonly.com/forums/general-q/274329-oil-pan-interferance-problem.html)
Likefastboats 04-12-2012 02:23 PM
I am in the process of installing offshore mounts on 500HP's with a gen 6 block and oil pan. The front of the oil pan is hitting the mount and won't allow the mount to match up with the bolt holes in the block. Has anyone had this problem? Is the only solution to go with aftermarket oil pans? If so does anyone have a pair of oil pans that will work for sale?
ROTAX454 04-12-2012 02:57 PM
Post a picture of the interference area. And if possible, several side shots of the front motor mount itself.
Thunderstruck 04-12-2012 03:30 PM
Is the mount backwards??? Stock merc mounts will fit gen VI oil pans. Had em for 10 years on my boat.
Likefastboats 04-12-2012 07:20 PM
2 Attachment(s)
Here are pics of the problem.
Raylar 04-12-2012 07:53 PM
I believe that oil pan will need a front mount Merc Part # 844341T02 .
Best Regards,
Ray @ Raylar
mike tkach 04-12-2012 07:54 PM
mount looks like it needs to be turned around 180 deg.:party-smiley-004:
Raylar 04-12-2012 08:16 PM
Ridefast77 has two Gil front mounts for sale in the swap shop section that might work, check the depth carefully.
Best Regards,
Ray @ Raylar
Thunderstruck 04-13-2012 09:15 AM
You said you have 500HP' "S" so you have twins? The merc mounts are LH and RH with separate part numbers so the LH won't fit on the RH motor and vice versa.
ROTAX454 04-13-2012 09:53 AM
1 Attachment(s)
All good info here guys. Again, the OSO brotherhood comes thru. I do believe that the flange on the motor mount should face forward.
