Trim Tab / Tie Down Suggestions
Picked up a set of tabs today (thanks ridefast77) and was looking for some advice regarding mounting location. Sounds like the best area is as far outboard as possible just inside the chine. That lands them right on top of my tie downs. Should I just remount the ratchet on the trailer or mount the tabs inward? I really don't want to mess with moving the eyelets on the transom so that isn't an option for me. Any help is much appreciated!
http://farm6.staticflickr.com/5071/7...b36202ab_c.jpg 2012-04-12_21-09-36_798 by hopper75, on Flickr |
Easiest/best would look to relocate the rachets further out.
My strap go thru the hinge of my K-plains for a pretty much straight shot. Wouldn't work with the bennet type tabs. |
Move the mounts on the trailer as far outside as you can.
IMO your tabs should be mounted between the middle 2 chines not way out towards the ends so strap clearance shouldn't be an issue. There shouldn't be any interferance with the drive steering either, that's why the K planes are angled. Just my 2cts.
Originally Posted by fireboatpilot
(Post 3662768)
I have done some research on this and I want to move mine inward and horizontal. My theory is I can run them in a more neutral position so they act like an extension of a hull instead of digging in. But, this is just a theory! :D |
Originally Posted by onesickpantera
(Post 3662856)
I agree. When you put them out too far you need a negative angle for them to contact the water causing more of a dragging/snowplowing affect.
Everything look ok with this mounting area?
http://farm8.staticflickr.com/7086/7...6f04c1a7_b.jpg trim tab location by hopper75, on Flickr |
| All times are GMT -5. The time now is 10:16 PM. |
