Stelling extension box question >
Old 04-15-2012 | 10:54 PM
Default Stelling extension box question
I was under the impression with the Stelling box that there were three placement settings against the transom up1", neutral. or down 1". I placed the box against my transom just to be sure with the gimbal bolted on and was surprised to see that in the middle hole my gimbal bearing would be too high, but if I used the highest hole config. on the box my gimbal lined up. I'm not using the Stelling driveline too much pain in the ass to install using Imco driveshafts so alignment has to be on
homan is offline
Old 04-15-2012 | 11:02 PM
On mine the top set of holes are nuetral, middle hole is -1" and using the bottom holes gave me -2".
cbell is offline
Old 04-15-2012 | 11:23 PM
something is not right !
DareDevil is offline
Old 04-16-2012 | 12:23 PM
Originally Posted by cbell
on myne the top set of holes are nuetral, middle hole is -1" and using the bottom holes gave me -2".
+1
JaayTeee is offline
Old 04-16-2012 | 07:35 PM
yeah that's what this seems to be top = neutral
homan is offline
Old 04-16-2012 | 07:52 PM
tcelano's Avatar
Merc boxes are set up the same. Top holes give you stock drive height.
tcelano is offline
