500 EFI tulips valves.
New valve springs on, and valves burned into tulips on 500EFI what`s the major fault?
Fatigued valves, not-so-great quality to begin with.
LEAN/sky high egts- I put a holley projection on a small block in a old truck I had years ago and tuliped the valves towing hard in the winter time because it wasn't rich enough, Smitty
Leaned out. Check the injectors. They most likely need to be flow tested and cleaned. I tulip'd 6 out of 8 intakes and dropped a valve seat on a SB Mag motor when the injectors began flowing poorly.
When you did the springs, did you happen to make any other changes to the engine....ie. cam, bump in compression, etc.
Eddie |
500 EFI Tulips valves
Thanks for replys, Eddie I did not do the job myself,the former owner tels me that he put works to the heads with new Comcam springs,but I can see that the heads has been milled and has a milled surface.This motor supposed to have a serie #0M050186 and if I got it right it should be with H beems rods, this motor has the 502 pistons and rods,I know the first models 500EFI had mostly the same internals as a 502 Mag MPI (not heads,pushrods,lifters and cam) In this matter I dont know the part# on the Comp cam springs and the lifters looks not like the origin 500 EFI,the springs looked to me to be very stiff,appreciate your oppinions here,thanks.
Bjorn. |
just start over. you have no clue what was done right or wrong.
what was the timing set at?
Originally Posted by dereknkathy
(Post 3667589)
500EFI tulips valves
It`s right I have no clue what was done right or wrong here,but it`s nice to hear other guys experience about things in this matter,no I did not check out the timing befor I took it apart.
| All times are GMT -5. The time now is 06:39 PM. |
