502MPI rebuild having some issues >
Old 05-01-2012, 02:08 AM
Is your cmi exhaust new? Pressure checked before you put it on? Had the same issues @ idle & now in need of a rebuild because the exhaust was dumping water on a piston!
jmoore1225 is offline
Old 05-01-2012, 07:09 AM
Originally Posted by high&Dry
update:
so tuesday before leaving for Havasu, swapped lines at oil filter (that was the only thing that was plumbed wrong) and checked filter for debris. The filter was clean so I installed a new one. I also pulled my IAC and found it to be rusty and stuck in the closed position. I went out for a quick lake test and immediately noted a HUGE improvement. Oil pressure solid at 60-70 and oil temps never got above 180. Once I ran it a little harder oil got to 200 or so and never any hotter than that.
Thanks to everyone for their engine saving input!!
The idle is still inconsistent though, after running for about 7 hours at havasu, it still wants to die when brought back to idle slowly, and just poking around in the canal, it felt like it could die at any minute, and did more than once. If you bring the idle up to 1000 is very pulsating but eventually evens out and won't die at that rpm level. I changed the map sensor on one day using a friends that was working fine on his boat, but still no change. I looked for manifold leaks with spray test but none are apparent.
Any ideas?
1997 GenVI 502 mpi with vst and mefi1
Only issue is at idle, the boat jumps out of the hole with no hesitation, and pulls very hard all the way to 5000 with no issues at all. The boat ran 67 gps with a 23p hydro Q4
am glad you coaught this before you killed it. well done.
don't forget to change the oil now that you have some time on it. as for the idle ... it could be a million things but try to think horses and not zebras...
idle is a function of tiny pulse widths at the injectors and small carefully metered amounts of air. if the idle can be maintained correctly static and its smooth then you can make some assumptions from that. it doesn't take much... the fuel and air flows are so small at idle that it doesn't take much to make them " wrong " and turn your idle to sht. and if the idle is shabby and weak then i would go looking for vacuum leaks from a cracked line or something you forgot to put on.
failing that i would have the injectors out and clean them. flow cleaner backwards thru them and pulse them with a scanner until they fan correctly.
on mine i found that a couple of things were common... first that they get rusty and dirty pretty easy and the fan gets shabby and the other is that it takes nothing at all to clog the screens.
a good spray pattern is really crucial to making an injection system work properly. for me it was a simple matter of taking a pump and a can of very aggressive cleaner and with a hose and a clamp pumping fuel to the injector from both directions while pulsing it with a scanner. you could see the pattern clean up immediatly and the junk that would come out of the screens was significant.
i suggest this to you because your boat has been sitting around while the motor was being done so the tank has some junk in it and the lines might...
you have two things to remember ... first that you have had everything apart there is to have... so touch and rub all that stuff again... and second, things like filters and old fuel and all manner of forgotten stuff will consire against you from the boat sitting... make sure all that is correct first... and have another look at the iac and make sure ir moves smoothly and that the seat and port are clean. and if you don't have a scanner , buy one. it is a crucial piece of equipment for you. i have one if you need it
horses... not zebras
stevesxm is offline
Old 05-01-2012, 04:31 PM
Received 1,825 Likes on 910 Posts
Have you checked the timing????? It should be set at 8* when put into base timing mode.
Griff is offline
Old 05-02-2012, 03:19 AM
MikeScarab28XLT's Avatar
Short question to the experts.
MEFI 1 502EFI 1993.
Diacom read over 3100RPM to WOT only 29,53 Spark advance.
Base time are set so 8°.
EFI dont make 34° at WOT is it nomal?
Thank you.
MikeScarab28XLT is offline
Old 05-02-2012, 04:19 AM
MEFI 1 502EFI 1993.
Thank you.
well... a few things...
first you have to look at which ecu you have and what the total timing is supposed to be in that unit .
second, make sure that no one has " reflashed it" and changed whatever they could have changed.
third, check the diacom numbers with a proper jumper and timing light just to make sure you are actually interpreting your diacom data properly ... i useded the much much older diacom systems on oldsmobile motors and the data was often "raw" and did not actually answer the quetion you thought you were asking...
and fourth... i suppose you could have something triggering the knock sensor and backing the timing off...
stevesxm is offline
Old 05-03-2012, 03:56 AM
Hello stevesxm,
thank you for the info.
I have the first MEFI 9550 two ECM´s and two ECM´s reprogramed.
If i drive with 2500 RPM i see in diacom 37° and with the timing light i go with -37° to 0° with the light. At WOT diacom shows me 29,53°, but i have not read it with the light.
Now what make me confused. I have Base Time 5° for test.
Diacom Show 37° and timing light shows 37°, but not 34° at 0 ore 37° at -3°. Where are the 3°.
I have test base Time 0° and 10° all the same. I have no Crankposition sensor.
All other people have say to me. Diacom shows only the Table and i have to add the 8°.
Diacom 29 + 8 = 37 ???
ore is it
Diacom 29 = 29 real with base 8
Diacom 29 = 31 real with base 10
Diacom 29 = 33 real with base 12
I have no Table from the ECM 9550 so i can not say what the timing shout do at 4860 RPM.
Old 05-03-2012, 03:59 AM
"and fourth... i suppose you could have something triggering the knock sensor and backing the timing off... "
Can the flappers in the Imco Endtips can do this ??
Old 05-03-2012, 07:29 PM
i'm sorry but i simply don't know. i understand what you are saying and i understand your confusion but wiythout seeing the screen and the understanding the current diacom data, i would just be guessing in an area where it is not smart to do so. i think if i am standing where you are i am going to just make absolutely certain that i understand the timing marks i am looking at and i would use a very simple timing light... one without the advance dial... and make sure i wasn't running 37 degrees or anything like that...
beyond that you need someone genuinely familiar with whatever version of the software that diacom is running now. and i apologize but thats not me. have you tried contacting diacom ? when i was using their stuff you could just call them and talk to them...
stevesxm is offline
Old 05-04-2012, 06:25 AM
OK good idea, i ask Rinda. What the Spark Advance Show me.
I can use the timing light with 0 like a light without the advance.
I see in Base time 8° with light at 0°
I see in Base time 0° with light at 8°
I see in Rinda 29,53 at 3100RPM with timing light 29 i see at 0° the light.
I ask Rinda.
Old 05-04-2012, 10:33 AM
[QUOTE=MikeScarab28XLT;3679117]OK good idea, i ask Rinda. What the Spark Advance Show me.
I ask Rinda.[/QUOT
they are or were a very good company. when i
" knew " them they were actually making all the oem test equipment for GM ... a GM factory scanner was actually a rinda designed and manufactured piece... so they aren't some aftermarket outfit... they have been around for very long time and have ( or at least used to have ) the inside track at GM ... so i would start there.
but first just make sure you don't have TOO much timing in the thing and do some harm before you get your answer.
stevesxm is offline
