Alternator
Old 04-23-2012 | 09:19 AM
Default Alternator
I'm looking at upgrading my stereo system by adding a 5 channel amp. I have an '01 Baja Hammer with a 454 MPI completely stock. Currently running 2 batteries would like to add another battery and was wondering if i need to get a new alternator? I'm trying to find a decent alternator w/o spending a bunch of money. Any ideas? I checked KE performance but didn't know if anyone else has done this and what would work the best.
svt_22 is offline
Old 04-23-2012 | 09:27 AM
onesickpantera's Avatar
http://www.dbelectrical.com/c-7745-universal-fit.aspx
I've been running the 105amp 1 wire for a few years with no issues.
onesickpantera is offline
Old 04-23-2012 | 09:28 AM
Adr0334?
svt_22 is offline
Old 04-23-2012 | 02:21 PM
Originally Posted by svt_22
Adr0334?
Yes. http://www.dbelectrical.com/p-3609-n...e-adr0334.aspx
Not sure if 105 amps is enough for what you're doing but they have great customer service and their product has held up well for me.
Old 04-23-2012 | 05:06 PM
johnnyboatman's Avatar
needed one myself thanks for the heads up.
johnnyboatman is offline
Old 04-24-2012 | 10:33 AM
Should i be running one of these also?
http://www.remybattery.com/ProMarine...381C2437.aspx#
svt_22 is offline
Old 04-24-2012 | 11:04 AM
considering that you can run a whole house on 105 amps, if 105 amps isn't enough he needs to just get a small nuke from a sub i guess...
stevesxm is offline
Old 04-24-2012 | 04:08 PM
105 amps at 110 volts is 10 times the power as 105 amps at 12 volts. 1200 watt amp needs 100 amps at 12 volts. that being said, the stereo won't be pushing 1200 watts continuously and a 100 or so amp alt should do the trick.
dereknkathy is offline
Old 04-24-2012 | 10:18 PM
Just get a group 29M deep cycle battery dedicated to running the stereo amp. I can run my 1100rms watt system at moderate to high volumes for 4-6 hrs on one.
Griff is offline
Old 04-25-2012 | 04:00 AM
watts are watts. and the "audio" output claimed by the the stereo guys has little to do with the power supply that drives the amplifier. just look at the little tag on the bottom to see what it actually draws...
in addition... none of this is running on the alternator... it all runs on the batteries... so take the ac watts required to run all the equipment, run that number up against what the inverter requires in dc watts to produce it ... take that number and put it against the amp hour capacity of the batteries and divide by two and thats how long the system would run with NO charging. and that is likely to be between 1 and 3 hours at 100 % capacity ...
a 100 amp alternator, at, probably, 2000 rpm would keep those batteries charged until the end of time if he ran the thing loud enough for me to hear him from here , non stop.
stevesxm is offline
