Pressure testing manifolds
That is A LOT of pressure, I'd vote NO. On my Stainless Marine manifolds, there was probably 100sq.in on either side of the casting, you're looking at 4-5000 pounds of force. I'd pressurize to a couple psi, with air, maybe a bike pump, and dunk the manifold in water, look for bubbles.
It is still 40-50psi and a good set of manifolds can handle that pressure with no problem.
I had the first gen stainless marine bbc manifolds and that is exactly how I tested mine. My water pressure built up to about 30 psi.
BTW--on mine, the aluminum bottoms were fine and I found a crack in one of my ss riser pipes (the inner pipe).
Good Luck, FT
Good Luck, FT
