fuel return lines from VST done.. >
Old 04-28-2012 | 05:51 AM
Default fuel return lines from VST done..
Was sick of Vapor lock so I ran the return lines back to the tank (fuel fill hose) CP Performance has a coupler for this I just added an additional bung for twins. some people wanted me to post pics... Will start today and check for leaks if it stops raining. Took a little time but I think looks ok..
silent lucidity is offline
Old 04-28-2012 | 08:17 AM
should help a bunch..factory setup is B/S
ezstriper is offline
Old 04-30-2012 | 01:44 PM
Attachment 473904
Attachment 473905
Attachment 473906
Fired her up and YEA no leaks.. Oil changed, water seperators changes.. Cleaned and ready to go.. Need one little thing to make me happy... about 80hp's,,,,,,,,
Old 06-01-2012 | 05:53 PM
second chance's Avatar
I want to do this also. Do you know what size plug I need to cap off the VST? also, what type of fitting did you use to connect the AN fitting to the return line?
second chance is offline
