GM engine oil supplement (EOS) anyone use it?
As some of you may know I had the low oil pressure alarm sender let go on one of my engines and piss a bunch of oil out to the point I had some real rattling lifters before I shut it down . Afriend who I respect suggested I go to the GM dealer and get some EOS, said it would be a good idea given this situation, Ive never heard of the stuff, anyone ever use it???........thanks Doug
I use it on every new engine I put in at work.
What is it?
Can you use it in a older motor to help with anything?
Description Size Item # EOS — Engine Assembly Prelube Specifically formulated as an engine assembly lubricant. E.O.S. provides outstanding protection against run-in wear and piston scuffing, as well as run-in camshaft lobe and lifter scuffing resulting from insufficient lubrication. 16oz. p/n 1052367 |
| All times are GMT -5. The time now is 12:22 PM. |
