-   -   Wiring Harness ?? (https://www.offshoreonly.com/forums/general-q/275979-wiring-harness.html)
Profile1234 05-07-2012 03:07 PM
Wiring Harness ??
My boat is wired with a 14 pin harness, i am repowering with a 500 HP which takes the 10 pin connector. Can i simply cut the 14 pin plug off and wire the 10 pin on?? Will the colors match up or is it not that simple??
Carbon Footprint 05-07-2012 09:07 PM
there are adapters out there that connect the two, look around online, I used one when I put a newer 496 mag HO in an older formula. I think I paid $ 60
motorz 05-09-2012 11:07 AM
Ok this is what you are going to need.
84-892444T02
-reverse adapter that allows installing an older (10 pin) engine into a newer (14 pin) boat.
motorz 05-09-2012 11:11 AM
If you had Smarcraft you are going to need some extra connectors (Merc standard plugs) If you have DTS ... You might need a new dash + more ..
