crossover and th housing setup >
Old 05-08-2012 | 09:24 PM
Default crossover and th housing setup
I want to know if i can run with crossover and thermostat without bypass if i drill a hole in the thermostat?
I want to run the egine at 150F in a 65-70F water temp. Is that this hole will drop too much my engine temp?
Any help will be appreciated.
supermx96 is offline
Old 05-08-2012 | 09:43 PM
Aren't you installing a supercharger? Any reason why you want to run the engine at 150* and run a thermostat?
You cannot run a thermostat without a bypass. When the thermostat is closed, how is your exhaust gonna get water? Drilling a hole isnt enough. Not too mention the water PSI issues you'd be having.
MILD THUNDER is offline
Old 05-08-2012 | 10:25 PM
Yes i have just install a (B&M 250) on a merc 525sc with CMI headers. For the th setup what do you recommend? I know i need a good oil temp i dont have oil temp gauge for noe but the engine is setup with the stock merc oil thermostat.
For the water temp i dont want to run it to low and making condensation. Do you run without th and still have a good water temp?
Old 05-08-2012 | 10:28 PM
I've never ran water stats. Just oil stats. Water temps around 100-110* on my stuff. Cold water temps helps ward off detonation.
Old 05-08-2012 | 10:45 PM
You have never get engine problem at that water temp?
What is your temp at idle?
I will probably try to run without stats this summer, Do you put water restrictor to help to control temp?
I know that he have several people run her engine like that, but does the engine need more piston to cylinder wall clearance due to less expansion of the cylinder block?
Old 05-09-2012 | 07:00 AM
I would be most concerned about water pressure. I had to put pressure relief valves, and water dumps on both engines. I was seeing pressure around 40-50.
1BIGJIM is offline
